B
babyface123
Hi,
I have a newly converted second floor flat which needs a separate meter and electricity supply installed.
The ground floor currently has a 3 phase supply with a spare fuse.
I have contacted UK power networks who have come to view this 3 phase supply and have said it should be fine to install a new meter and supply to the newly converted flat via this 3 phase supply.
I have however contacted British gas, and asked if they could connect a new meter to this 3 phase supply, however because the supply is 200A they will not touch it.
I have gone back to UK Power networks and they have said the following:
'you cannot run a service straight from the 200A cut out to the meter for the flat as the smallest tails you can get in a 200A cut out is 75mm ideally a distribution board should be provided which then distributes power to all parties or the meter dept may accept an isolator in between the 75mm tails and the required 25mm tails '
Could someone let me know what would be the easiest/cheapest solution for me......installing a distribution board or an isolator?
Also is it worth contacting other meter companies now to see if they can help or shall I contact a private electrician to install a distribution board or isolator first before contacting another meter company
Would really appreciate some advice, and if it makes any difference the flat is in South London
Many thanks
New Meter Install From 3 Phase Supply
DIY Electrical Advice
babyface123,
Darkwood,
