W
Wilko
Hi - long story if you've time, with a question at the end
I was at a new build tonight, a 2br flat, part of a block of 28 done by a big company. I'm there to change 3 light fittings, but couldn't refrain from having a look while I was there. Certs in place, looking reas good in CU which was metal with 2 RCD. TNCS. Nice 16mm going from cutout to CU but only one 10mm coming out. Read cert and it says 'bonding to gas' but no mention of water. Look under sink, there is the brass stop cock with copper pipes to and from but no bonding evident. Looked for the gas bonding conductor but couldn't find it either. So I got Wander out and checked, sure nuff boiler gas inlet pipe was 0.05 ohms to MET, but the water stop cock was floating. So remembering @Pete999 vid I used my insulation tester and got 180K Ohms on the 250V test. So I'm guessing they judged the incoming water supply not an extraneous conductive part, so they hadn't bonded it. Likely all the flats will be the same. To me this is a gutsy call. Is it correct?
