K
Kash
Hi,
I am currently having my whole house renovated and I am also having a new outhouse built (brick/block cavity wall etc..). We want to put a small kitchen in the outhouse and so will need to run Gas and Electric etc... We will also be putting the boiler and unvented cylinder in the outhouse.
I already know about the trench requirements etc... I would like to know about cable, consumer unit requirements.
I wont be doing any of the work my self and will be bringing a qualified electrician, but I like to know the best approach with these things, which why I am here.
I have read you can spur off the original house CU, as long as you use the side that is not connected to the RCD? Is that even the case when having a oven etc... ? I understand the CU in the house will have it's own RCD so that should cover it, just wanted confirmation?
Also in regards to cable its about 20m (max) from the outhouse to where the current house consumer unit (main fuse) is. What thickness armored cable would be recommend?
We will most likely have to upgrade the existing consumer unit as we are also building a extension and building a dormer and there aren't enough mcb's in the current unit, what would be the recommendation for the size of unit?
The house will be (after extending) 5 Bed, 2 Bath, 2 Reception, a WC, Kitchen then outhouse with another small kitchen (with the boiler and cylinder).
I hope I have provided enough information.
Appreciate any advice given.
Hi,
Sorry there is no where near enough information. The best advice any one could give is to get your electrician involved now at design stage. One thing I will say is you would be better with a switch fuse for the distribution circuit for selectivity.
Agree with above. Your sparky will give you all the answers you need.
  • Agree
Reactions: DPG and Pete999
As you said you are employing an electrician to do the work so they will be designing it. The cable size will depend upon many factors including load allowing for diversity (not all loads on together) As for consumer unit size this will depend on what existing circuits you have and additional new ones but the best option would be all RCBO's
  • Agree
Reactions: Deleted account
I'm also with the above posts. Have a word with the electrician who will be installing and testing the circuit to the outhouse. He/she will tell you what is best.
One option is, add an extra CU next to the existing one. This way you are not touching the existing CU. This will save money. Again, have a word with the electrician. He/she will advice on this.
Not sure I agree with that ... the whole house is being renovated and extended ..
True mate but it sounds like the OP is not touching the existing wiring. I may have misread it... Maybe the OP can clarify please.
There are may ways to skin a cat.. I suggested one... :)
  • Optimistic
Reactions: 1 person
Why do you need to know any of this?
Just wondering why the customer needs quite so much detail about the install...
Could be that the OP is intending to do the job himself or that he is just curious as to what is needed.
If the OP is actually "bringing a qualified electrician" to do the work then they need to have a word with the electrician about the best way to do this and what is needed. After all, the electrician will be putting their name down on the cert and notifying the relevant authorities.
Too many specific questions from the OP. And why don't they ask the spark who will be doing it?
Answers on a postcard (not you Murdoch)
  • Funny
Reactions: telectrix and Spoon
Don't worry my friend you won't have to think about any of this your electrician will do that for you
Thank you for the replies.
Couple of points for clarity.
I appreciate an electrician will provide this information, however when you call an electrician, you can end up getting a lot of cowboys, so its good to make sure you have a reasonable understanding of what is required rather then assume all electricians are equal :) - Plus I have OCD :)
PS: Yes the whole house being renovated, new electrics, new plumbing, new plaster, new ceilings etc....
PS2: Yes the system boiler and the cylinder will be in the outhouse, I have spoken to three four plumbers about this and this should be fine. The pipe will be run underground (1m in depth and fully insulated).
Anyway, I managed to get hold of a friend of friend (who is a fully qualified electrician - just too busy to do the job) and went through what I am planning to have done he recommended the following:
He said to take the direct feed from the meter into a new henly blocks. The henly blocks will supply main home CU and the outhouse CU. A 16mm armored cable will be run from the henly to the outhouse CU.
He recommended 16mm, as I will have boiler and kitchen (oven, microwave) in the outhouse.
I spoke to a few other electricians some said I could get away with 10mm but... most said stick with 16mm to be safe.
So, who is doing this work?
Shouldn't you be talking to the electrician who will actually be doing the job?
Reactions: DPG
Hilarious stuff this. The OP should write sitcoms.
  • Funny
Reactions: chris gray and DPG
So the builders has finally bought in a electrician to do the job as the trenches have just finished being dug out. The electrician will be doing all the work. I asked him about the setup as well and he basically gave me a few options and one of those was what I wrote above.
Not sure what is so funny. Just curious about how all this would work, the answers I was getting back on this forum was ask the electrician (who wasn't around at the time), so I thought I would ask here considering that's the point of this forum?
I am guessing people probably take it as free advice or think I might be crazy and do the install my self.
Anyway I am sorted now.
Who is doing the rewire then?
Sounds fishy
why would ANYBODY put the boiler in a separate building 20 meters away? That just sounds so odd.
And the kitchen,normaly a domestic kitchen is part of a domestic dwelling unless this is to be used as a small commercial kitchen.
I thought this at first too, however someone on our road this this as well (5 houses down) went to speak to them about it, and so far so good. Nothing major bills wise and they don't need to worry about using up space within the house for the cylinder etc.. One other benefit is the the plumbers are happy because they have really easy access to boiler and cylinder, normally when they are inside the house they are housed in cupboards etc... which can be a pain.
Sounds fishy
Builder bought in his own electrician who will do the wiring. However I am up for bringing in my own person? anyone here want a job, rewire whole house and the new outhouse.
Would it be cynical to suggest the OP and builder are one and the same? Of course it would be, perish the thought. Builders never do electrics...….do they?
LOL I work in IT, don't do any building work, getting loft, extension and new outhouse, etc.... just want a good and above board job done, so asking question. You guys are way to suspicious.
As I said, send me a pm and ill be happy for you to come down and quote me. I live in the East London area so you have an idea of where you would have to come to.
Almost, Mrs does a lot of baking on the side (she is thinking of starting a business etc..) Since we are having gas, electric and water running to the outhouse, we thought it would make sense to make a kitchen for possible future venture there, that's all.
Reactions: Toneyz
  • Funny
Reactions: 1 person
Just thought I'd end the conversation here. Thank you all for responding.
As I said, happy to get alternative quotes, if you can send me a PM ill give you the details.
5 Bed
2 Bath
2 Receptions
a WC
Extension (Kitchen)
Outhouse (Boiler/Cylinder and Kitchen)
All new wiring for main house and new sockets, light switches, light fixtures.
New CU for main house
New CU for outhouse
It's a big job. The house is completely gutted now, so no need to worry about wiring runs (should be easier). The ground floor has a crawl space about 3ft and enough of the floor boards off to make wiring runs easier there.
All plaster is off the wall, and ill have the builder do any chasing etc...
5 Bed
2 Bath
2 Receptions
a WC
Extension (Kitchen)
New CU for outhouse
With the job that far advanced it's leaving it a little late to engage an electrician, doesnt sound like a great deal of forward planning is in place.
Outhouse Consumer Unit and Underground Cable
Kash,
Deleted member 9648,
