T
Tom281193
Hi,
I’ve been recently working on a living trailer for a friend, when they have the supplies connected (240VAC 16A) they have nuisance tripping on the RCD. I’ve traced through and found an outside waterproof socket to be at fault, short circuit between live and earth. Removed the socket and tested, fault was not on socket, short still within the wiring. So I traced the cable back to a small joint box about 3M away. When I disconnect the cable from the box, then test of both sides of the connection box, there is no short. But as soon as I wire the cable back up the short comes back. I’ve completely removed the connection box and used inline crimps (to eliminate the connection box for testing) still the short is there. But when all is disconnected, each cable is fault free. Only when everything is connected will the fault reappear?
Any ideas?
Any ideas?
