C cruelty Oct 8, 2011 #1 hi, does the forum support Tapatalk?? if not why?? similar style forum are all on it... thanks
Sparky Ninja ~ Mentor Arms Aug 18, 2009 2,680 883 1,688 North East If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at? United Kingdom What type of forum member are you? Heavily Qualified Electrician / Teacher / Tutor - etc Oct 8, 2011 #2 This forum works on Tapatalk.
Sparky Ninja ~ Mentor Arms Aug 18, 2009 2,680 883 1,688 North East If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at? United Kingdom What type of forum member are you? Heavily Qualified Electrician / Teacher / Tutor - etc Oct 8, 2011 #3 Yep, just double checking. Sent from my iPhone using Tapatalk
G Guest123 Oct 9, 2011 #4 Yes, Tapatalk is supported on all our forums, unless you use a Shatberry like me which is still in the Beta version.
