Discuss Wiring a light from a socket in the DIY Electrical Advice area at ElectriciansForums.net
behhjja
I am trying to add a switch and a light into a storage room next to our kitchen. I am wiring from a socket in the kitchen into another socket in the storage room - that works. Then I am wiring a lighting fixture from the socket (which turns on when I switch on the fuse). From the lighting fixture I am taking another wire to a switch, that doesn't work and trips the fuse when I try to switch the light off.
This was a working circuit before that I had to take off due to damp proofing the storage.
My guess is that I don't wire the switch in correctly as for some reason this is and intermediate switch used as 1way.
See attached diagram and switch.
Could someone help me please what could be the issue?
Thanks!
TL;DR
Trying to wire a light from a socket. When I add the switch to the circuit, it trips the fuse.
How are you fusing down the feed to the light/switch?
I also think he’s switching across L and N
If this is how the wiring is run, then you need to look for examples of “loop in” or “3 plate” lighting circuits online.
As mentioned, the lighting circuit needs fused down where it comes off the socket.
Reply to Wiring a light from a socket in the DIY Electrical Advice area at ElectriciansForums.net
I am adding a light fixture in a room I am restoring in my 160 yo house. I have ran a new 12-2 w/ground wire from the ceiling box to a junction...
Hi, I am installing a new bathroom fan. We had an electrician who ran 14/3 into a junction box. The black feeds a led light and the red was...
Hi I want to add a light to my attic. There is a single switch on the landing that I want to change to a double switch and then use it to still...
Hi, I would like to add a new socket in the bedroom. Current room configuration: 3 existing sockets - wiring coming from the bottom (under the...
