Currently reading:
C&G 2365 Level 3/Safe isolation and testing
Discuss C&G 2365 Level 3/Safe isolation and testing in the UK Electrical Forum area at ElectriciansForums.net
Hello everyone.
I am due to take my practical exam for Level 3 on Monday but am totally unprepared. I seriously struggle to remember the safe isolation and testing procedures so literally ANY advice would be perfect right now.
Thanks!
Jake
Permission
Identify Isolation point for circuit
Switch off, Lock off, post notice
Use two pole voltage tester
Test on known live
test on circuit worked on
If Dead, test on known live again
All clear? Start work.
Btw when doing practical they look for Live on last and off first in every combo.
Permission
Test on known live
That's so simple! Also in what order do I test in? My mind is totally blank and sadly it had to happen just days before my exam
Permission
Test on known live
Thank you by the way, didn't mean for my response to come across without seeming grateful
Switch off loads then switch off supply, remove cover from board, install lock off device and sign put the key in your pocket or that's a fail!
Then 12 point test, if you don't count 12 you have missed 1 and it is a fail
1- test lamps in proving unit
2- L1 to earth
3- L2 to earth
4- L3 to earth
5- L1 to neutral
6- L2 to neutral
7- L3 to neutral
8- L1 to L2
9- L2 to L3
10- L1 to L3
11- neutral to earth
12- test lamps in proving unit
2- L1 to earth
3- L2 to earth
4- L3 to earth
5- L1 to neutral
6- L2 to neutral
7- L3 to neutral
8- L1 to L2
9- L2 to L3
10- L1 to L3
Would these steps be relevant to all circuits?
the steps I posted are if your isolating a three phase board at the main isolator, remember to test on the primary side of the isolator where the cable comes in!
These steps are the same if your isolating a 3 phase circuit and for a single phase circuit, L-N, L-E and E - N test lamps before and after!
Do you have an on site guide? All the diagrams in there for testing with good pictures
Don't forget your PPE. Some colleges require you to select appropriate PPE like rubber gloves (marigolds), googles/safety glasses, stand on rubber mat (usually provided) etc. Sometimes it will be a black test box that you test at, not the actual isolater/mcb but the tests as described above are the same.
Jay
I'll get all the steps written down to better prepare myself. I do indeed have the OSG so I'll give it a read to see if that helps
Jay
I was wondering if any specific PPE was required but if so they I will be able to find it at college
Remember a golden rule that applies throughout the testing regime,test (and null where necessary) your instruments before using or relying on their readings or values
The safe isolation test you mentioned is half to do with testing the instrument before actually relying on it to give an accurate result
Might sound silly but when would I null the test instrument? I assume it'd come be after lock off but I may be wrong?
What instrument are you using? cant see how you are going to null a voltage indicator, it will either indicate a voltage or it wont. You prove whether it is working by using a proving unit.
Hello everyone.
Thanks!
Jake
Please remember what you asked in the opening question
The lad wanted tips on testing procedure,he would be, or at least should be, aware of the functions and operating procedure of each instrument/range:rolleyes:
Fair enough, although the original question focused on the safe isolation procedure, which was why I made the valid point that a voltage indicator is what it is and cannot be nulled, Jake's answer as to whether he should null the instrument after lock off, seemed to me at least he thought the point you brought up about null as required, indicated to Jake that the Voltage indicator should be nulled, my reply was meant to assure him that there is not a need, or more importantly no method to null a VI, also I made the point that a VI is proved before and after use. I'm sorry if that offended anyone, most of all Jake.
I have quoted my own post because.in fairness to Pete,although no criticism would be reasonable or even intended of himself,I can see where twisted knickers have been introduced to the thread
Having re read my own post,I can see where Jake has mistakenly assumed the 2nd part was indicating a voltage tester
The safe isolation procedure "is"part self test of the instrument,however, it will of course have no relevance to adjusting/nulling applicable to other test procedures
I am also sorry for any confusion he may have been presented by myself
Reply to C&G 2365 Level 3/Safe isolation and testing in the UK Electrical Forum area at ElectriciansForums.net
