Whilst i can only recommend i just think a new consumer unit would enhance the safety of the installation. It would be more accessible, provide extra ways for circuits that are doubled up. There seems to be quite a few sockets that are spured of an already unfused spur from the ring. I was going to suggest splitting the ring into two radials, but again there is no room in the current unit. If im classing the boiler supply as a C2 and the customer wants a report that is satisfactory i really cant see how i am going to go about replacing the MCB for one of a lower rating
What's the story with the shower?
Nice!
Don't get yourself into the customer wants a satisfactory report game. Take the advice I was given when it went pear shaped for me. Report and if they want the work doing, quote for it as a separate work item.
If you can't squeeze a new MCB in that board, then could you not take an SFCU from the ring close to the boiler and then disconnect that circuit at the CU?
6mm2 T&E feed that has been extended with through crimps inside the shower unit using 2.5mm
Deffo C2 and unsatisfactory.
Submit invoice and report.....
A satisfactory report will need more money spent...... So get paid for the report
Reactions: Des 56
Not without alot of disruption to decoration, that consumer unit is a nightmare to work in. Its just about accessible for the user if anything trips.
Did they build the stairs around the DB?
That is a tight space and with that stupid shaped shelf that doesn't help changing the board will be as much work if not more!
Question 2 Is the husband still around or has she buried him?
  • Funny
Reactions: Des 56 and DPG
Yeah he's still around, he was giving it the " i dont know why she wants this work done its been fine for years " line, when i was there. Thinking of moving the DB directly under that shelf if possible. I certainly wouldnt want to keep it in there
time to get the hammer out.
The customer is aware that if they require a satisfactory report then they are going to have to spend more money to have the remedial work done. Once i have copied the report from draft form i am going to have a sit down with them to discuss there options
I think I'd get my bill in before talking though any of it with them to be honest
leep82
Stoke on Trent
Business Name
L.M.P Electrical
Neutral-Earth voltage
leep82,
davesparks,
