dvymac
I'm looking to data points for Cat6 in a couple rooms through out my house. Plan is Patch Panel, though brushed panel, through eaves, terminating in a gang faceplate. I've got easy access to eaves so getting the cables from one wall to another should be easy enough.
The walls are plasterboard/drywall. But a few years back they had rigid insulation glued to back of them. The Kingspan foil-backed insulation type stuff.
Hasn't been any wiring done since. The existing wiring seems to either be cut into a channel in-between the wall and the insulation, or the insulation is mounted off the wall with an air-gap. That's in different places, not all the insulation was the same job.
Any advice for best way to feed cables through without compromising the insulation.
If i Do cut a square straight through the plasterboard and the insulation, I could stuff the square hole of the insulation with some pieces of soft blanket insulation used elsewhere.
Cheers,
Dave
Cheers,
Dave
