Discuss Dual fan and light ceiling fan slider switch in the UK Electrical Forum area at ElectriciansForums.net
I need help wiring a dual slider switch for a ceiling fan and light kit. The ceiling fan and light are already wired and mounted and have been in place for more than 10 years. There was a rocker style switch which I removed without making note of how it was connected. The box I'm working in has six cables. One freewire, and four two wire. I have been able to identify the hot wire from the breaker box and four of the remaining five black wires all feed separate outlets in the same room. I have no idea what the sixth black wire does. All of the white wires are still connected under a wire nut inside the box and have not been removed or disturbed. I have looked at the schematic of the switch and pondered this wiring setup and still cannot come up with the solution.
I’ll tell you what I would do is hook up what you know and don’t hook up the other wire, turn the power on and see what’s not working. I’m assuming that you have a non contact voltage and tape your spare wire
Reply to Dual fan and light ceiling fan slider switch in the UK Electrical Forum area at ElectriciansForums.net
Hi, have an old bathroom fan. Which has two wires the black and red (line and neutral). The fan has no isolator switch and was powered when the...
Hi, I'm looking to install a new bathroom extractor fan in my bathroom as I have a windowless bathroom and the current one I have installed in...
Thinking a 240V AC relay activated by two independent light switches could be used to switch power to a shared inline extractor fan. The fan...
L
WIRING FOR WALL SMART SWITCH FOR CEILING FAN/LIGHT Just bought a smart wall switch for a ceiling fan/light currently connected to a single switch...
littletwinn
L
Hello, I'm swapping my extractor fan in the UK and I have bought a Turkish extractor fan stupidly and the connections you can see in the picture...
