Discuss Table lamp to ceiling lamp, is that possible? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
forget it. apart from the fact that it may not besuitable, it's bloody hideous.
let me put it this way. if you had just built a boat, would you launch it keel up?
1. it may overheat.
3. you might make a pig's ear of it.
4. you could electrocute yourself: fall off the steps: cause a fire. take your pick
Even if the bulb is the same?
basic law of physics. heat rises. therefore the heat that rises from the bulb away from it's holder as a table lamp will , on the ceiling, rise into the lamp holder and may cause overheating.
Bonkers.
Search google for ''Revolting blue frosted glass lamp/lampshade'' under shopping and if you get no suitable search returns, then you may get a blue candle or summit.
The problem is that I still did not find any nice ceiling lamp shade...
I corrected your post for you buddy!
table lamps are like turf. green side up, or in this case , blue.
I would like to do that because I did not find a nice ceiling lamp for my bedroom, similar to the bedside table lamp, that's why I thought to convert a table lamp to ceiling one, to have them similar.
By the way, this is the table lamp I would like to put on the ceiling GAVIK Table lamp - blue/frosted glass - IKEA , of course without the top cover, just the body.
Reply to Table lamp to ceiling lamp, is that possible? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
