Discuss Help with EICR code! in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Thanks for the replies
so matter how long the circuit is as long as th end to ends are ok and the zs is below 1.15 then there are no real issues with circuit length?
how are you going to do this on a periodic inspection?
How do you think?
It's not hard to briefly check voltage at both the distribution board at both ends of a cable using your test instrument. I often do it on larger runs within manufacturing sheds, Factories etc. due to high load currents, additions to the circuit drawing extra currents etc. Albeit this is more than likely domestic so it probably won't apply but still.
How do you think?
Well, you are right, I shouldn't make assumptions about it being domestic but then we are talking about a ring final and recommended floor area here........ ;)
Reply to Help with EICR code! in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
