OP
Discuss Veritas R8 alarm Control Panel Sound Problem in the DIY Electrical Advice area at ElectriciansForums.net
ok we need to do some tests to find the fault......leave all cables in, and with short piece of wire, bridge out terminals D & C and also short out tamper terminals.....replace cover, and that should get rid of tamper light, then repost you result, and we will go from there
.....with your 90`s job, this is not far from it with global tampers...lol...but then 5 pirs on a zone was common then.
Sounds like you have your work cut out there...photos are always useful for members to see some of these so called pro installs
Reply to Veritas R8 alarm Control Panel Sound Problem in the DIY Electrical Advice area at ElectriciansForums.net
