View attachment 123140Hi,
I have an old pottery wheel that i am desperately trying to fix. Does anyone know what any of these parts are/ do ? any help would be really apprecaited.
Hi !! Yes I have been referring to the same diagram … it’s pretty similar but not Exaclty the same. I was reccomended to put in a 2 amp fuse instead of the desired 1A and it fried one of the brown striped (I assume resistor) type components. Do you think best to replace them ?
To answer your original questionView attachment 123140Hi,
Thankyou for all your help !
Hae ordered solder remover tape and am going t unsolder the wiring to get a closer look at the board, and replace the fried resistor. Also ordered some correct 1 A fuses. Oce ive got the board off and ill post a picture for any help regarding how much resistance i should get my raplcement component for. Will update in a few days!
so to be clear , i will remove the blue/ grey capacitor and fried resistor .. order the attached filter, and solder it from the bottom right tag (with the green resistor) to the tag directly above where the blue one used to sit?I suggest replacing the burnt resistor and the blue/grey capacitor (which I suspect is faulty and the cause of the resistor failing) with a single component rated for the job. This just needs to connect between the bottom two right-hand tags on the board (in the upper pic with your hand!)
Example from Digikey, but you can find such elsewhere. 470 ohms is a satisfactory alternative to the 560 you have
PMR209MC6100M470R30 | DigiKey Electronics
Order today, ships today. PMR209MC6100M470R30 – RC EMI Filter 1st Order Low Pass 1 Channel R = 470Ohms, C = 0.1µF Radial from KEMET. Pricing and Availability on millions of electronic components from Digi-Key Electronics.www.digikey.co.uk
I think it's essential not to put that blue grey capacitor back, unless it is tested and found to be sound at mains voltage. It is not essential to the function of the machine, other than for suppressing interference, so you could leave both R1 and C1 off the board for the moment and check if the machine works when you put it all back.
Hello !
I have now de soldered the board and managed to get it off the wheel. going forward i have a few questions...
During the de soldering process, will the wiring be faulty when i re wire it if some of the rubber housing has melted in places?
furthermore, i am attempting to take off the fried resistor (i have confirmed it is R1) and the wire is wrapped round the port and then soldered on. I have been using desoldering wick but still cant get it off- any reccomendations / would it be fine to cut the fried resistor off with wire cutters?
Also , the resistors have different sizes and positionings of the stripes on them, does this indicate that they all have different resistance. The next step i will do is try and order a replacement resistor and maybe (as reccomended above)another capacitor (although not sure which type).
As always.. any help is very much apprecaited !View attachment 123183View attachment 123184
Hello !
Absolutely correct.so to be clear , i will remove the blue/ grey capacitor and fried resistor .. order the attached filter, and solder it from the bottom right tag (with the green resistor) to the tag directly above where the blue one used to sit?
After , wire it back up again and test...
I think the letter 'W' within the omega symbol is the trademark of the manufacturer - Welwyn Components as they are known.so , i replacd the capacitor with a newer one and resistor with a metal film resistor (680 ohms). Fired it up.. i suppose good news as nothing actually fried up this time, but the machine was still unresponsive and nothing started with power. Did some live voltage tests and noticed a significant drop around this first resistor (R4) so have removed it and will try a replacement.
Does anyone know the power and resistance on it- i am not sure which number is which as the Watt sign is inside the Ohms sign. ?
Will try and soure a suitable replacement roday and then test
Has the fuse gone?Thankyou , that is all very helpful . Although now i am very puzzled-changed the resistor back to the original green wire wound one, and cant get a reading for 240 volts (which i had previously got) anywhere in the circuit, even at the first connection from the live wire. all my readings are in the 10-30 volt range... so maybe not enough power ? i figured this as was trying to measure for DC on the bridge rectifiers and the reading was zero. not sure what the next step would be from here ?
Correct. The blue wires at the bridge rectifiers are mains neutral.Actually .. now that you say it , as its the nuetral i am thinking that the blue wiring to and from the variac actually SHOULD be no voltage ?
You say the mains is going to the start/stop buttons, but doesn't appear on its output. That could be part of, or the whole, problem. If the start/stop switch put mains on it's middle wire (which goes to the left hand tag of the overload thing), if the overload thing then output that on the adjacent terminal on the diagram, that then connects to terminal 7 (from the left) of the strip, which then goes to the relay coil, it would energise the relay which would switch on the motor.The 2 amp overload (below) does have two buttons on it - the left button im pretty sure is reset, and the right button pops out the left. I reset it and the volatges flowing out where all much higher ! (so i expect no the cause). The start/stop buttons are wired into a plug that i cant seem to open probably with out breaking the case for the switch, but 240v was flowing in to the switch and the grey wire (4th terminal along) only reading 20v. The switch also used to make a sound when pressed and now there is nothing ... maybe i should take that apart ?
