Discuss Accidental connection of earth in the Lighting Forum area at ElectriciansForums.net
I inadvertently connected earth wire to L in bathroom pull cord switch as well as the live wire, I connected the other wire to L1, when I switched light on it worked ok but when switching it off and on again it tripped the breaker as it should, however when I reset breaker light came on and was ok. Why would it stay on and be ok with earth connected to live?
Sounds like you may have a poor earth on that circuit or possibly no earth on the whole installation which could be a DNO earthing issue. I would suggest you get an electrician in to get the circuit / installation checked out ASAP
Ok thanks, will do that. Once I connected the earth to where it should have been ( in daylight where I could see ) everything was fine, but should get it checked anyway .. Thank you.
It’s only 10 minutes work for a sparks to check the house earthing and check the earthing at that point. Certainly worth doing.
You probably realise that it’s important to be sure that if any metal appliance (E.g) washing machine has its casing become live then the relevant protective device will operate.
While correcting your connection error on the surface it may appear to be fine your error in connecting the earth and live conductors together has highlighted an underlying problem with that circuit or potentially the whole installation
Most definitely yes you should for your safety and the safety of others in the property as @timhoward says it is not a big job to have it checked
Reply to Accidental connection of earth in the Lighting Forum area at ElectriciansForums.net
DIY query Have narrowed down the source of an occasional trip to one light circuit which is a varilight v-pro master dimmer slave set up. This...
Hello, I’m trying to change a pendent light, I’ve wired it the same as the previous light that was on there however the light is now permanently...
I have carried out home wiring for 60 years as a competent person, for the last 20 years, I employ a local electrician to check my work and sign...
M
Hi Guys I purchased some of the above online around 3 weeks ago, They are a fairly new product, very usefull as you can change both colour from...
Hi guys, I have recently encountered that my circuit breaker for the upstairs lights keeps tripping. I flick it back on and immediately it trips...
