Discuss Best Sub-board for 8.1kwh Solar PV? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi,
Can you advise the best and most suitable Sub-board for an 8.1 kWh Solar PV System, with Battery and 2x Inverters, Energy Diverter and Gateway? It will be separate from the main household RCD.
Thank you.
They could, but they unfortunately used the main household RCD initially, and it keeps nuisance tripping:-/ So, I’m seeking my own clarification on which sub-board would be the most appropriate.
Ah I see. Well hager is a good brand but generally pricey. You could also use an rcbo in your original board rather than a new sub board
Thanks Matthew, I do have a Hager, which is what they have used. From other threads on here members have recommended a Sub board. Is there a particular model, rating or type that is suitable for my system?
Reply to Best Sub-board for 8.1kwh Solar PV? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
I am a Napit registered electrician and want to get into Solar PV and battery storage. I have boot camp booked in April but am not hearing good...
Hi got a 8 panel solar system on bungalow, changing the board to 18th edition spd board Solar feed is chased into wall so will this need a type B...
Hello fellow professionals, I'm currently facing a challenging scenario that involves the integration of solar photovoltaic (PV) systems on roofs...
Greetings, everyone, After dedicating over a month to researching Solar PV systems, I'm nearly ready to make a decision. I owe my progress to...
Hello everyone, I currently have two solar modules left over from an installation and I would like to use them to set up a solar system on the...
