R
Rothjon
Hi all, I'm looking at installing a led security light. I intend to run it from the upstairs lighting circuit which is rcd protected. It will cause too much mess getting cables to the loft from the ring main. So does this sound ok, turn the power off obviously then cut the lighting feed cable in the loft, rejoin in a junction box along with another 1mm twin and earth cable, run the spur cable to a double pole switch then run another 1mm cable from switch to outside light. Just to add I can't come off the last rose on the circuit as the rose is in a lowered ceiling. I'm thinking this is right but am I missing something? Any advice will be gladly appreciated. Cheers.
