Discuss Bonding if plastic income? in the UK Electrical Forum area at ElectriciansForums.net
Is it best just to test the pipe you think may need bonding?
If it is plastic - bonding it,will only mitigate against static shocks,like those hanging strips,you saw dangling off the back of Mk I Escorts,in the 70's :)
haha... I think the OP is talking about bonding copper pipes that are attached to a plastic infeed pipe.
My water supply pipe is plastic but the internal pipework needed bonding because it is in contact with the damp cellar walls. As said, just test it in each case to be certain.
If the entire internal pipe installation is in copper I'd be inclined to main bond it regardless of plastic incoming supply, I think there's something about that in the OSG ?
Reply to Bonding if plastic income? in the UK Electrical Forum area at ElectriciansForums.net
No waffling, going to get straight to the point. Main water on the exterior of the building in plastic. Changes to copper inside the building...
Greetings, I am homeowner and looking to confirm if I will need earth boding to water pipes. There is already earth boding near Gas meter and the...
I know once you see plastic entering then you don’t need to bond as it says on site guide.(enters the house plastic then it’s metal) Would I be...
Incoming supply on our job comes into the building and then the tails from which go into a switched isolator with 200A fuses fitted. No idea...
Hello, Carrying out remedial work on a commercial site and I've come across a metal out building that has a water supply to it. The water pipe...
