Search the forum,
Discuss Celing fan wiring HELP in the DIY Electrical Advice area at ElectriciansForums.net
J
James Walters
Hi I have brought a ceiling fan from argos, I have attempted to wire it in see pics
The problem is when you turn the electrics back on the fan comes on as does the light when you turn it off at the socket it trips the electrics my wiring must be wrong but not sure where?
pics wont open.
Plugged in the socket, is it?
You've got the lives and the neutrals in the wrong terminals. Not sure that this would cause the tripping fault you describe but it's incorrect none the less.
Lives are both red, switched live is black with red tape last black is neutral, greens/yellows are earths.................brown from fan-to black with red tape, blue from fan to single black. connect all yellow/greens together. reds connected together but not connected to fan
Reply to Celing fan wiring HELP in the DIY Electrical Advice area at ElectriciansForums.net
