L
Leigh Duffy
Hi guys,
I hope somebody may be able to help me out. I've installed wiring for a home network in Cat5e, running cables to most rooms and terminating in modular outlets.
These terminations can be seen here:
https://www.dropbox.com/s/5ifgub477l19om7/IMAG0186.jpg
and I have matched the 8x cores of the Cat5e to their respective colours.
At the other, central, end of each run I want to terminate the cable straight into RJ45 jacks which I intend to plug directly into an 8-port switch hidden in our cloakroom.
I am wondering in what order the 8x cables need to be terminated into each RJ45 jack to ensure the connections are consistent with (i) the data signals being sent from the switch and (ii) the data transmitted from the wall module via ethernet cable to the device?
I have looked at two ethernet cables I have at home and their orders, from left to right as viewed with cable clip facing downwards, are:
Any pointers in the right direction with this would be most appreciated.
Thanks in advance,
Leigh.
- orange/white, orange, blue/white, blue, green/white, green, brown/white, brown
- blue, orange, green, brown
Thanks in advance,
Leigh.
