Discuss CU Change help in the UK Electrical Forum area at ElectriciansForums.net
An update, given up on the idea after being pi**ed about, either no one wants it for whatever reason or its yeehaa types, I refuse to do it, no access to an mft, had one, got nicked, no need to get one for one job and certs not up to date for testing so sod it.
... yeah I can re-qualify and join a scam ...
You do realise that you don't need to be a member of a scam to do a CU swap don't you ? It sounds to me like you have the experience to be considered competent to do the work. I suspect your biggest problems will be access to an MFT and the cost of a notification to your LABC dept.
the recall of a 6amp mcb that was Meany years ago ,
A very small number of Electrium MCBs, sold under the brand names Wylex, Crabtree (Loadstar only) and Volex are not perfroming to the required characteristics. This can lead to a potential risk of burning, in a small number of installations.
Models affected
MCB Rating: 6 Amp
Wylex: NSB06
Crabtree (Loadstar only): 6M1B06
Volex: VB06
MCB Rating: 10 Amp
Wylex: NSB10
Crabtree (Loadstar only): 6M1B10
Volex: VB10
MCB Rating: 16 Amp
Wylex: NSB16
Crabtree (Loadstar only): 6M1B16
Volex: VB16
I remember that Buzz!! I made a bundle out of that recall......good times!!! :)
I'll just leave here, it may help shine a light on my attitude on this matter.
Years ago I asked by a friend to look at his CU with a view to swapping it for a larger one or piggy back a smaller on for a garage. I refused, I hadn't done much in the way domestic switch gear and was'nt a scam member, refusal ended up ending that friendship.
So this chap, who wasn't short of money found his own electrician to do the work, when I say electrician I use the term loosely, he was in fact a glorified maintenance man. To cut to the chase, some time later there was a electrical fire, caused by burning cable in the meter and CU cupboard that also had boots and coats in.
No one was hurt but, I don't know how the system works his insurance found out the work wasn't notified and refused the claim, I'm not sure what happened after that.
Now back to present day, I have years of experience in industrial electrical work, some domestic as well, I'm a pain in the rear for following the book, no ifs and buts, I can do my own CU no problem but wont because:
1) I no longer have a mft so I cant or wont do live tests, dead tests yeah but those mean little if the rest cant be done if you do not have the gear, do not do the job, simple.
2) if I can not guarantee I will leave the installation in a better condition than I found it I wont touch it with a long pole.
3) All of my work was done to a high standard, I may be a little ocd in that department but I expect the same from everyone else.
Finally I wont put my family at risk, its all I have and wont put them at risk just to shave a bob or two off, I can assure anyone that with my luck, if things go wrong I am first in the queue.
As for the LABC, well I have my views on that, on one hand its supposed to cut out poor workmanship but on the other, its money going to some jobs worth fat **** that's creaming it of another's hard work but the rules are set even if they don't work.
Wonder what would happen if someone just sent them a letter advising work done, included test results and pictures and ending the letter with; if you want to come and inspect it that's fine but I won't pay for your time. ?
Yeah, that's a bit of a problem if you don't know someone well enough to be able to borrow one.
I understand that, it's my approach as well - which is why, at my last job, I didn't get to do a lot of network installation jobs as they were subbed out to people who'd do them in half the time. The problem comes when trying to find a tradesman who can work to the same standards, and who you can afford :rolleyes:
I think we have similar views ;)
Having said that, my dealings with the BC inspectors have been very positive. I did some notifiable work at the last house, got one of them to come round in advance, agreed the work to be done (I was opening up a hole in a wall to make a cupboard over the stairs), and once I'd got the new lintel in he came back to check and I got the completion certificate a few days later.
I put in a notice at the last house to change the CU - and just sent the lower fee. The inspector did ask about tests and I just said "I'll be providing results" without being any more specific. My plan was to do my own EIC and just send that - I doubt they'd have been bothered as it means they have a magic certificate that protects their backside :cool:
We ended up moving before I got round to doing it, so I didn't get to test their attitude. I expect to be doing it with this house at some point.
I can borrow an mft if I ask nicely and offer more than its worth in beer, the problem is giving it back, it will have to be prised by my cold dead hands first, buying a new one with a cal cert isnt really an option, it wont pay for its self, unless screwfarce will loan one for day...... ahem.
Had two dealings with our labc. one while having a internal wall removed, the lady was absolutely brilliant and nice to deal with. Other was a friends outside swimming pool, it was a matter wanting so much for the pool filled and chucking him in it then filling it in with concrete and building a house over it.
I missed out on a few jobs because I wanted things doing my way, so it went to someone cheaper, its always the way, annoys me because its a great opportunity to show off your skills, with cabling or networking you can see it, anyone can, not so much in a CU or switch gear cabinet, yeah I like cable p*orn :)
Reply to CU Change help in the UK Electrical Forum area at ElectriciansForums.net
I'm not sure what's going on with my kitchen light. I've replaced an old 28W CFL fitting with a new 4 x LED GU10 fitting (a cheap one from...
Hi, as the title says, I need to change the upper heating element on my HE10AB220/C oven. I've never done that and it seems pretty easy, as in...
i have just started my course as a trainee electrician...some advice on the following will be appreciated: I have a spare 16 and 32A MCB (RCD...
I have just been called out to another burning shower switch.Upon removal the wires had been burnt and chared.One thing I've noticed on all burnt...
