Discuss Earthing conductor also bonding the water...is this allowed?... in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
EC appears to be clamped to the water pipe just before going outside to the spike. Was this ever standard?
Fair do's. I've got to change a board following a EICR. Installation is TT but has no RCD protection whatsoever. Looks like it was only installed in last 5/10 years plus an extension was added earlier in the year, no certs or anything. Just the tip of the iceberg to.that's exactly what i'm saying. how many RCDs get tested regularly by pressing the test button? very few. then you come along with your posh MFT and test 'em and they don't work, so you press the yellow ---, and they back working. who's to know if they would work if needed to save a life?
Fit a timed contactor which creates a N-E fault every 3 months.
Voila...automatic RCD testing!
Archy that's not as daft as it sounds! I've often thought about things like this and I just end up putting them to the back of my mind, that and 'built in' smoke/heat detectors for those dodgy connections! All in all I think they could contribute to a safer install, but I'm not sure where to go with these ideas.
Edit:
The quarterly test reminder would have an audio and visual output and not just trip at time out![/QUOTE]
Aye .. it could flash-up a message on the 52" flat screen telly right in the middle of Jeremy Kyle!
Reply to Earthing conductor also bonding the water...is this allowed?... in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
