Discuss Emergency Lighting Design in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Is it ok to have 3 phases in that arrangement??? As you would have 3 different points of isolation in one accessorie.
Or does it just require a warning label above the switches.
Its permitted Dazza yeah.
You see it all the time in industrial setups - a 3 gang gridswitch with the 3 gangs each supplied with a different phase and feeding out to fittings from there.
Your correct in that a 400V warning label is required though.
I can imagine Tiny, ive seen a similar thing with a timed supply to Ambirad heaters........very dangerous and makes you wonder how some 'sparks' manage to sleep at night!
Reply to Emergency Lighting Design in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi guys, Been asked to fit 2 lights and a switch, which in reality turned out to be rewiring a multiple PIR setup to a single switch, adding...
Hi Guys I've fitted a few emergency lighting circuits to both domestic and commercial installs before, I've come across one I can't get my head...
Hi I'm in need of some advice. First of all i'm not an electrician but do have an understanding of electrics as i come from an electronics...
Hi all can a Maintained emergency exit bulk head light fed from non lighting circuit if it is correctly fused and test point provided if no...
