Search the forum,
Discuss First Anniversary Generation figures in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Today my 4kw system has reached its 1[SUP]st[/SUP] anniversarywith a pleasing 3338 KwH generated in last 12 months. System is 16 Hyundai 250Wpanels facing due west and SMA 4000TL.
This is some 433w over the SAP, which I suppose is normnowadays. My friends 4Kw system, which is split equally east, & westreached its first anniversary recently with a total generation of 2935KwH,which from memory is pretty close to the SAP he was given.
Looking forward to the next 12 months when hopefully theweather here in north Essex will be little more the norm with far sunnier days.Annual rainfall in this area is normally less than Beirut or Jerusalem but overthe last year it has like most areas in the UK been somewhat different.
Thanks Brightaspark, be good if others could post 1st Anniversary figures too so we could use this thread as a repository (and take any discussions about a particular installation to another thread :) )
Thanks for the feedback. I am also in north Essex in a village called great yeldham and have a 3.92kw south facing system that was installed on March 26th and we have also reached 3338kwh today.
- - - Updated - - -
3338kWh generated compared to SAP of 2905kWh is 15% outperformance of SAP.
My system, a 3.75kWp facing, ESE, 40' slope in Cambridgeshire (an adjacent county to Essex), is currently 13% above the seasonally-adjusted SAP estimate, so is pretty close to the 15% outperformance of your system, give or take that mine has a couple of months to go for its full-year and much of its time so far has been this horrible weather of 2012!
Mine has 15x 250W Kinve KV250-60Monocrystalline panels (strings of 7+8; same orientation) and PowerOne 3600 indoor-model inverter.
My SAP target was reached in mid-October (installed Jan). Currently up to 3140kWh, would expect to be up around 3350 by its anniversary in a couple of months time.
Thanks Worcester - good idea and should give members confidence that their systems are performing ok. Willl be interesting to see how things develop as installations age etc.
I will post some figures from another friend (yes I have two) whose 3.75Kw system SE facing is due to get to its first anniversary shortly
SW Scotland (DG7) 18 x Kioto Panels and Aurora3.8OUT(3.6KW) facing SSE minor shading. 20 October was 1 year 3028 KWH was expecting 2800 ish .
Norwich outskirts-16x240w Sanyo panels facing about 10 degrees west of south, with slight shading when the sun is low. 3683 on gen meter on OCT 4th but 3880 as SAP quote(always suspected it should be 3380)
As per Jan-Feb 2012; I'm really noticing the drop-off on my panels at the moment - the sun doesn't even sit opposite the panels at any point in the day, and is behind the panels before 2pm.
The SAP - and other estimations - definitely need an extra category for ESE or WSW as the solar potential in winter really does decline.
If my roof were various facings, the annual generation would be expected to be:
South: 3650
SSE or SSW: 3600 (98% of South)
SE or SW: 3400 (93% of South)
ESE or WSW: 3150 (86% of South; 93% of SE or SW)
E or W: 2850 (78% of South; 90% of ESE or WSW)
On sites such as PVOutput, the lack of discrimination between ESE and SE (7% difference) or WSW and SW (same difference) can cause a big distortion in expectations. This is even worse if someone who is SSE puts themself down as SE as they are likely to be 13% ahead of an ESE system, despite both being listed as SE).
Northern Cairngorms National Park. South facing, 45deg inclination, no shading. 15 x Sanyo HIT 245w = 3.675kwP plus Power One inverter. 12 month output = 3375kwh. SAP2005 = 3008kwh
It is generally recognised that on average a well designed and located system will outperform SAP by 10%.
Reply to First Anniversary Generation figures in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hello Is it possible for solar panel monitoring to over state the actual power generated by the system? My friend’s 6.4kW system has generated...
As a young man, I was an electrician, but now I'm getting on, I am strictly DIY. I used to have a cheap old 900W petrol generator connected to a...
Hello everyone my name is Tarek, i work as a concert and show lighting operator with over 20 years of experience in this field, so i have gained...
So I've recently purchased an ionizer from Walmart... going to withhold the name for now. Since I started using it I've experienced many strange...
Hi All got call out to a domestic fault on consumer unit totally separate from the job & client mentions to me that they had Battery storage...
12K
