Discuss Inverter Choice: SolarEdge, SMA SB3600TL or SMA SB4000TL? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
This is for the OP, I fully understand your queries, however your chosen supplier should be specifying the inverter for you and explaining the reasons why.
There are many you could use, and also some can be set with different options to minimise the shading issues that you have.
So my advise would be to choose a supplier that understands how inverters really work, just one example would be how optitrack works on an SMA, and would you benefit from using this facility on your installation.
Without surveying your house it really is impossible to suggest which inverter would perform the best, although for different reasons many have their favourites.
I hope this helps.
Ps Most, not all but most DNO's require a maximum output of 16A, which is 3.68 KW without having prior permission to connect to the grid, some inverters are supplied this way(G83 approved), and some can be set to this.
Thanks Earthstore,
To be fair to the installer, I approached him to enquire about pricing for a SolarEdge system, and to ask how it would compare to SMA (as I’d had other quotes for SMA systems).
He’s had a look at the house, and listened to my thoughts and proposed an SMA system with 10 panels in one string, and 5 panels in another. The 5 panel string will cover the area that will get some shading to minimise the effect of it.
He’s said DNO approval won’t be a problem, but I asked him to quote for both the 4000 and 3600 so I could compare the difference in price.
I’m leaning towards the SMA system, but I’m undecided on which out of the two inverters to go for. This thread was about ensuring my thoughts were on the right track.
The only thing about putting 5 panels on one tracker is it may be doubtful if it would have enough voltage to kick a 4000TL inverter in IE 5x30V=150V, Of course it depends on the orientation of both arrays.
So it depends on the panel voltage really, and total system design.
Both arrays would have the same orientation. Basically all south facing on the same roof.
I can't be sure but I would say that this is due to the fact that one of the strings will be running at a higher voltage and will therefore start up earlier - although I would say that the actual benefit would be minimal.
Far better would be to consider the shading (however small) and adjust to suit.
Yingli panda 265w are 31v
4000TL default startup voltage is 150w (can be dropped to 125)
Mppt input range 175 -500v per string.
Voltage out of tracker range?
Power one for me 2 individual strings on trackers
string of 10 no problem the 5 may be under voltage though would need to run through the design
Reply to Inverter Choice: SolarEdge, SMA SB3600TL or SMA SB4000TL? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
R
Five days without solar but guess I haven’t missed too much yet, thanks to the grotty weather. I’ve had my solar installation since June 2011...
4K
iconnect
I
P
Hi guys, We are configuring up a 4kW solar pv array and the Sunny Design software (latest DB) is recommending an SMA 3000TL with our LG 250w -...
moggy1968
M
V
Hi - Im new to the Forum (today!) but have concern. I'm bit of a dumb blond when it comes to this stuff but here's hoping you guys might be able...
