Currently reading:
low voltage ip44 leds in bath panel??
Discuss low voltage ip44 leds in bath panel?? in the Australia area at ElectriciansForums.net
P
pierce
Hi , just want your thoughts on this , tiled bath panel sealed , with ip44 leds in the tiles, wired from existing switch , switch powering socket in loft lv transformer in plug pluged into skt and wired to leds in bath panel,
psc current of low voltage? because there is no earth in the lv cable if water did find its way in to the led ...? bad idea... or am i missing something.
If there is a panel that the LEDs are going into then put the transformer and socket behind that panel, as you need a tool to remove the panel, everything behind it is not within a zone.
As for the IP 44 not sure that will be particularly relevant as you can use SELV equipment not exceeding 25 volt in zone 1.
Reply to low voltage ip44 leds in bath panel?? in the Australia area at ElectriciansForums.net
