Search the forum,
Discuss low voltage ip44 leds in bath panel?? in the Australia area at ElectriciansForums.net
P
pierce
Hi , just want your thoughts on this , tiled bath panel sealed , with ip44 leds in the tiles, wired from existing switch , switch powering socket in loft lv transformer in plug pluged into skt and wired to leds in bath panel,
psc current of low voltage? because there is no earth in the lv cable if water did find its way in to the led ...? bad idea... or am i missing something.
If there is a panel that the LEDs are going into then put the transformer and socket behind that panel, as you need a tool to remove the panel, everything behind it is not within a zone.
As for the IP 44 not sure that will be particularly relevant as you can use SELV equipment not exceeding 25 volt in zone 1.
Reply to low voltage ip44 leds in bath panel?? in the Australia area at ElectriciansForums.net
I have undercabinet lights that are low voltage. They work xenon pucks just fine. I want to convert to low voltage LEDS. Supposedly these are...
Hello, I live in Mexico, where I have a small, un-official trailer park on my property. The property is serviced by my privately owned, 650amp...
Hi All, I've installed a Lorex doorbell recently, but it is not turning on. I did some tests using a multimeter and this is what I found...
I have a 115vac line that tests with proper voltage and will power a low watt bulb but will not run a drill etc... Line from main panel to barn...
Hi, I have bought a LED Lighting Strip (20 metres) to sit inside some Screwfix coving for my bedroom. Although it will be controlled by the...
