Discuss Mcb to fit MEM fuse carrier in the UK Electrical Forum area at ElectriciansForums.net
Anyone point me in the direction of what MCBs will fit this board ? Thanks in advance
I have one MEM MCB of a similar vintage but have no idea if it will fit that CU.
Not much use I know but the newer, black lettered, MEMs are very different from the older red lettered ones.
I agree I'm almost certain these are just an early version of Memshield 2. Looking at the various MCBs there have been a number of small design changes...
There's also the 'commercial' range, which were branded 'Bill', if my hazy memory serves me right.
They're all interchangeable, except that (IIRC) at some point the 'fingers' on the bus bar were reduced in width, and later devices won't fit the earlier bar.
Reply to Mcb to fit MEM fuse carrier in the UK Electrical Forum area at ElectriciansForums.net
Wallbox Fuse Box Lite Single Phase has anyone used one of these? I've installed one feeding a Pulsar Max, the Pulsar Max is set to 32Amp max. The...
Two questions: 1. I’ve had a bulb in the hall turn black with some white powdery deposits (see photo), whats caused this, guessing i should get...
Has anyone come across click accessories spurs burning out? it seems to only be happening with the CNS200 Trend uk Steibel eltron heaters Fuse...
hello all...whats the typical cost for a new consumer unit fitted and the old wired fuse box removed im in a semi detached house in...
