Simon Hall
I have a pump running for a swimming pool but after about 10 mins it trips out does any one know why this is happening it's run off a non rcd board thanks
it trips out the whole board
So it's tripping every MCB/blowing every fuse?
That certainly is an odd problem.
Hi sorry the pump has just had bearings changed, it trips out the whole board then won't switch back on again after tripping out, I thought it was the rating on the breaker but it's ran off the same breaker for 8 years without a problem. Also the cable is ok
take it out, smack it's arse, put it back in. well, it works with women!
You've got your women well trained!![]()
