dtec dave
I have been out to a nuisance tripping RCD this morning, there are 3 socket circuits, 1 boiler circuit, and 1 oven circuit protected by the RCD.
I started by checking the IR between L-E and N-E, the reading was between 2 and 3 M ohms on every circuit and leg.
I then disconnected the CPCs for each circuit in turn and I was still getting between 2 and 3 M ohms between L and the earth bar.
I disconnected all the CPCs and was getting varying readings between the lives and CPCs of the other circuits.
I was also getting varying voltages between the L and CPC's even when the RCD was turned off.
I was also getting various voltages between the different CPCs
Can anyone explain what would cause this?
Cheers
Cheers
