Discuss Socket off a spur to a garage in the DIY Electrical Advice area at ElectriciansForums.net
Hi there, I just want check that what I am doing is to the regs. I am not an electrician but work in related trade. I have asked a couple of electricians but they have given me different answers so I am slightly confused. I currently have a garage supply with a garage consumer unit (16a for a socket and 6a for lighting), feeding one socket, with a freezer connected and a light. The garage supply is fed from a spur off the the ring in the lounge (just a tv, x box etc). From the socket in the lounge there is a spur to a junction box and then swa to the garage (about an 8 m run). I want to to install an outdoor socket. From the spur, if I replace the junction box with a 13amp fcu, can I then feed an outdoor socket (occasional use 1600w outdoor patio heater) and the garage from this fcu?
If the spur in the lounge has a 13A fuse, and everything outside is protected by that fuse, then you can add what you like up to that 13A limit.
The circuit should, of course, be protected by an RCD or RCBO as well.
Reply to Socket off a spur to a garage in the DIY Electrical Advice area at ElectriciansForums.net
Hi, apologies for the basic question In a radial circuit, is it permissable to spur off the supply side of an existing fused connection unit...
Hello everyone, We had an electrician over, who fitted a 40a MCB in the house consumer unit to supply a new build garage. It's underground SWA...
Grateful if someone could offer some advise, I'm struggling to find a definitive answer to this. I have a double socket, it was on the ring main...
Hi, if getting back to the CU is not an option, instead of spurring off a socket via a Sfs putting the rating down to 13a. Could you spur off the...
DIY'er question: I have a singe switched fused spur above my kitchen counter, providing power to an undercounter fridge socket beneath it. The...
