- Reaction score
- 1,702
2.5c-2v cable (Japanese numbering system) appears to be standard 75ohm CCTV cable.I can't locate 2.5c-2v Coaxial Cable. Could I upsize coaxial?
I'm more familiar with the RG numbers used in UK
I think any 75ohm co-ax will do the job, but I guess you are looking for similar diameter
Mini RG-59 cable is 75 ohm and a similar size to yours. I think it has good enough electrical characteristics for your use, but a tinned steel core rather than copper, don't know if that matters in a vehicle!
I guess you don't need a whole reel? RS PRO Black Unterminated to Unterminated Mini RG-59 Coaxial Cable, 75 Ω 3.6mm OD 100m | RS Components - https://uk.rs-online.com/web/p/coaxial-cable/6655833
eBay to the rescue: RG59 Mini Cable | eBay - https://www.ebay.co.uk/itm/232842324054
I suggest soldering a joint (carefully!) is the way ahead!
