Hopefully someone is out there....:-)
I have a slight problem in that the cylinder stat I have needs a permanent live and earth, it then has a no and nc connection out, how do I connect the zone valve for the hw? Stumped!?
If you have an unvented cylinder then you'll also have to wire in the tank over temperature safety breaker too.
Live out from the HW controller in to the cylinder stat, out of that through safety trip switch and on to the DHW valve. Thats all there is to it.
Hopefully someone is out there....:)
What cylinder thermostat is it mate?
The hot water is being controlled from a neostat, all I have in the DH8RF is a hw c/no/nc connection. I have an esi 'smart stat'.
Thanks, believe it or not had it wired like that but lacking in confidence:-) Waiting for wet pants now hopefully it will all work, all a bit complicated, come back Honeywell all is forgiven!:-)
onwards on and upwards from here! next will be easier ;-) anyway it's those daft new tank stats, 5 core need now instead of 3 core. I don't rate them tbh.
Reactions: Leesparkykent
A mare, brother in law filled up and I remembered why we call him captain Leaky!:-),we are back tomorrow! I am still struggling to understand the wiring centre as it disables the UFH heating pump when just the hw or rad zones are on. I have it all connected up apart from the rad/ch pump (which I conveniently forgot!) I take I I just take this from the no boiler feed? My brain is fried, next week I am building myself a CH project board to get my head around all this!
A mare, brother in law filled up and I remembered why we call him captain Leaky!:),we are back tomorrow! I am still struggling to understand the wiring centre as it disables the UFH heating pump when just the hw or rad zones are on. I have it all connected up apart from the rad/ch pump (which I conveniently forgot!) I take I I just take this from the no boiler feed? My brain is fried, next week I am building myself a CH project board to get my head around all this!
The UFH pump should only come on if the UFH is calling for heat. If the UFH is calling the primary pump and UFH pump should be running if either the hot water or rads are calling for heat or both are calling for heat at the same time then the primary pump should only be running. What boiler has been installed?
The boiler is a wallstar, needed a permanent live and a switched, apparently with the uh8 if you set up a rad zone or if there is a call for hw it will not turn on the UFH pump which is on a separate feed. Unfortunately most of my day was spent sorting out other issues before I could start on the job in hand.
I'm not familiar with that boiler, so it doesn't have pump over run? you need to set the thermostat for the rad zone to 01 so it doesn't kick in the UFH pump.
Reactions: rolyberkin
Thanks for all your help yesterday, much appreciated, went back today and finished off, then the boiler wouldn't fire up, not my issue as it all had power just kept locking out!:-)
Sounds like a similar problem to what I experienced. Am sure the next thing they tell you is that the pump is not compatible..... Best of luck....
No the boiler needed a service, all the controls are fine, happy customer and he rates the system, would definitely put another one in!:-)
Heatmiser Wireless System
Central Heating Systems
rolyberkin,
rolyberkin,
