- Reaction score
- 8,224
Hi Derek,
Any chance of some pictures?
Discuss Cooker Hood Problem in the The Welcome Forum area at ElectriciansForums.net
Yes, controller provides the speed control to the motor across the 3 windings, 3 different resistances measured. I think it was something like, 58 ohms, 118, and 165 ohms. This indicates all windings have same resistance but are supplied at different intervals via the controller I think.Hi,has the motor got speed control,and is this achieved via the controller itself?
I took a couple photos on phone but new phone so I'll try and figure out how to upload. CheersHi Derek,
Hi WestwardDoes the motor do anything, like a humm or just nowt.
HiHi,it sounds like a Tapped winding type motor,which would have your four wires,usually the high speed is direct to main windings,(your first reading),with the medium and low being additional windings in series (your two other readings).
Has the motor got any nomenclature indicating it's operating voltage? only asking as some run at lower voltages,and if so,your mains injection may have upset it
Always tricky to diagnose from a keyboard...at this stage,i would still be keen to identify,type and fault...but i would have already fitted a new hood...just cheaper re: time spent
Hi - The fuse which blew was a 3A. I said earlier it was a Fused spur but it was a plug and socket so the 3A fuse was in plug. I replaced and this never blew again. The lights work via the controller. The controller also provides speed control. 3 output speeds. The windings of the motor seem intact as I have measured between what I think to be the windings. The readings pretty much double then treble.Capacitor is healthy(tested). Tried testing separately motor and controller. When switching each output speed, a voltage 240Vac could be seen at each output wire of controller (red, black, blue to neutral). When connecting brown of motor to mains L, which is where I believe it has to be wired to, the other windings (wires from motor, Red, Black, Blue) all seem to have a voltage on them when separate from controller. Would this be backfeeding to the outputs of the controller? If so then the brown wire which I believed to be permanently live may not be the case. I just wired it as it had been before so assumed this to be correct.
Reply to Cooker Hood Problem in the The Welcome Forum area at ElectriciansForums.net
