- Reaction score
- 0
Yes...tried bench run with new motor and new controller.Have you tried a bench run with the new motor.
Discuss Cooker Hood Problem in the The Welcome Forum area at ElectriciansForums.net
And does it run.Yes...tried bench run with new motor and new controller.
....Hence the threadIm guessing not :/
Hi - The fuse which blew was a 3A. I said earlier it was a Fused spur but it was a plug and socket so the 3A fuse was in plug. I replaced and this never blew again. The lights work via the controller. The controller also provides speed control. 3 output speeds. The windings of the motor seem intact as I have measured between what I think to be the windings. The readings pretty much double then treble.Capacitor is healthy(tested). Tried testing separately motor and controller. When switching each output speed, a voltage 240Vac could be seen at each output wire of controller (red, black, blue to neutral). When connecting brown of motor to mains L, which is where I believe it has to be wired to, the other windings (wires from motor, Red, Black, Blue) all seem to have a voltage on them when separate from controller. Would this be backfeeding to the outputs of the controller? If so then the brown wire which I believed to be permanently live may not be the case. I just wired it as it had been before so assumed this to be correct.Hi Derek and Welcome to the Forum !
Can I ask what size was the fuse that blew? Was it replaced and blew again? Sorry, just starter dumb questions. Do the lights still work? Probably it's in a million pieces just now I guess.
Edit - just reread OP so modified q.
Reply to Cooker Hood Problem in the The Welcome Forum area at ElectriciansForums.net
