I don't mind a dumb now and again..in fact I see I've got two on this thread now!
Another point regarding the current sharing thing, Zs is always highest at the furthest point on the ring, not what you'd expect if the resistance was equal at each point. (anticipating another dumb coming my way!!)
It’s why it’s good practice to have the heavier loads like in a kitchen in the middle part of the ring final circuit so current will flow equally through both legs and keeping the first 2 legs from the consumer unit short as possible, in practice it’s not always feasible tho.
Ok a Big apologies to all you clever clogg's I acknowledge my miss leading post and inaccurate comment, thank you for schooling to the correct position.
Top of the Class for Spinlondon and DPG!. well done boys, :oops:
Marconi sent me a private message yesterday explaining it very elegantly, what a nice guy!... :oops:
Any back to work and school for me...
humour is often the remedy to problems, nobody should take anything personal that is said on here, i dont see it as any different to ribbing the guys i work with, not everyone gets a stellar apprenticeship where they cover a variety of works, i certainly dont know everything about the trade, everyday is a schoolday as they say
Yep, I agree. Bit of banter/discussion/moderate arguing is a good thing generally. And we all learn stuff from here I'm sure.
everything in moderation, nobody wants to work with someone who loses the plot for no reason.
usually the big national company boys that struggle after their apprenticeship as most apprentices are used as cheap labour getting 1 or 2 jobs at a time and coming back to the foreman, not all but a good majority
one of the guys i worked with asked me for a flathead screwdriver, so i hand him the one i have in my pocket, it doesnt fit the screw so he launches it across the loft?!?! all because he was getting divorced apparently came to a head when he started shouting at me because HE FORGOT TO ORDER MATERIALS lol told him he had about 5 seconds to wind it in before he gets his jaw slackened.
we became buddies after that
Hooray somebody got it right at last!
Click the 'undo rating ' option at the bottom of the post.
  • Informative
Reactions: Risteard
Can’t undo or delete posts.
Reactions: willy fixit
You could ask a mod to delete it, if you've seriously embarrassed yourself, or edit it and just swear a lot will get the same response :)
I’m sure most ‘dumb’ ratings are people scrolling through on iPhone - too easy to do. Anyway - don’t let it get you down!
The layout of the buttons is a bit poor. (Please don't be offended by the "dumb" rating for this post - I just thought it would be funny...)
Sorry I thought you wanted to remove a dumb rating that you had made.
  • Funny
Reactions: Rpa07
About time ring circuits are banned....just a nuisance IMO in terms of testing, finding faults.
I remember reading somewhere that the ring main(as it was called then) came about after the 2nd world war when copper was in short supply, so the ring circuit was utilised, as prior to that they used radials.....and aren't we the only country to use them?
I couldn't disagree with you more. Ring finals are a very versatile circuit, when used in the right situation. Sure, I install more radials than I used to, but a 32A ring is often preferable to say a 32A 4mm radial, which you'd struggle to install in a compliant manner unless clipped direct through it's whole run. And we aren't the only country to use them! But even if we were, surely that's another reason to keep them. A Great British innovation.
I was maybe a bit harsh in having them banned!
Yes there are situations where a ring circuit is better e.g. sockets in a long corridor or a large hall. I do a lot of EICRs in university buildings and sometimes there's dozens if not hundreds of RFCs that have maybe five or six sockets on them, usually 4mm and in dado trunking with the DB in the same room or close by, and I just think, surely they could have put in a 4mm radial. I guess I see them as more work compared to radials!
nah, pull your 2 x T+E 2.5 cable to the last socket, then pull loops out at wherever you need them along the run, not much more effort than a radial
Yeah it isn't much more work when installing, but when there's a 36way 3phase board with about 20 odd RFCs in it to test on an EICR, then after a while you get fed up of disconnecting the legs and fannying on with tyrapped cables:mad:
yea, especially when some dougnut has twisted the earths together all the way back then popped their sheath on, makes a 2 minute job take 5
ive never done student accom though so cant say ive ever come across that many rings on 1 board :D
Ah yes two earths twisted in one sleeving.....thats the sign of an electrician who doesn't worry about the testing!
I do accommodation and academic buildings, the biggest EICR I did was the Engineering department, over 400 pages! And took about 8 weeks in total! It's a joy when they say you can't turn the sockets off.....great less for me to do and LIM in the boxes:)
The Chemistry department is even bigger, due next year...dreading it:eek:
Reactions: Upton Sparks
The RFC is unique to the UK, IMO very clever system, and I hate it when guys moan about it, when testing faulting etc , you are all just lazy.
Reactions: Rpa07 and KEV 1 N
Yes I am lazy!:p Anyway there's a night shift coming up soon to do an EICR in a large Uni office building......no RFCs.....it all radial circuits busbar trunking and floor sockets! Woohoo!:cool:
i thought i had it bad other day with a 25 circuit test split between 5 boards, any industrial/commercial i have done its been radials for the most part, and maybe a ring for the office area, rest is 3 phase machinery which is a doddle to test.
the effort they put into twisting the earths all the way back with pliers is probably more than it would take to individually sleeve them, at least i know when i leave a job nobody is going to be cursing my name when it comes time to replace anything lol
I know it infuriates me too! .
I pull a guy up on it once and he told me "it was because he didn't want to wast the Earth sleeving"....!!!!.???.!!! :mad:
It's £5 for a hundred meters!!!!!!
It's a shame he didn't have that concern with the Bloody Cable!!!!!......... I Wounder Why that is..
Reactions: Rpa07
sounds like if you asked some of these sparks to build you a square room you would end up with a sphere shaped room, cut all the corners ;)
it’s good practice [...] keeping the first 2 legs from the consumer unit short as possible
Actually not, in terms of imbalance, the reverse is true (although you still need to watch the Ze at the furthest point)
To illustrate I'll start with spinlondon's excellent example:
Ok.
If you have a ring that is 4m long with 3 sockets each 1m apart, the middle socket would have the same resistance on each leg. The other two sockets would have different resistance on each leg at a ratio of 3:1.
A 20A load connected to the middle socket would see 10A on each leg.
A 20A load connected to either of the other two sockets would see 15A on the short leg and 5A on the long.
Suppose we are worried about imbalance, so we shorten the two legs to the CU to 0.5m each.
The other two sockets would have different resistance on each leg at a ratio of 5:1.
A 20A load connected to either of the other two sockets would see 16.6A on the short leg and 3.3A on the long!
If you follow my suggestion and we make a loop of slack and extend the two legs to the CU to 2m each.
The other two sockets would have different resistance on each leg at a ratio of 3:2 i.e. 1.5:1.
A 20A load connected to either of the other two sockets would see 12A on the short leg and 8A on the long. Much better.
Hope this helps.
Actually not, in terms of imbalance, the reverse is true ...
Nice one. I'd spotted that, but couldn't be bothered to do a decent explanation.
  • Friendly
Reactions: johnduffell
Hope this helps.
F#ck me you need to get out more !
  • Funny
And this is why I avoid installing RFCs....
  • Dislike
Reactions: willy fixit and DPG
Scotland
Crossover in ring circuit
KeenPensioner,
willy fixit,
