OP
The Ghost
I think that is the best analysis so far.Doesn't look like you have enough wires otherwise.
Discuss Interesting three way conversion to two way and swap for time lag. in the UK Electrical Forum area at ElectriciansForums.net
Agreed, so make that the master. Now I have two wires going up to switch 3. And need to find the sw. return.Perm live switch 2
You could of just used standard time lag switches and got it working.Ok just to stop all speculation I installed sensor lights and arranged a permanent live and blanked off all switches. Sorry if you found this frustrating. As I intimated you would get to the point that it can't be done as you do not have enough cables and you would have to think of something else. I did not want to say this as I thought maybe some trainees would try to work it out. But there you go. Oh and I did not say I got it working with master and slave. I just said I got it working and thought outside the box. I was trying not to say what I did do. Anyway there is no way to get the live up to sw. 2 and 3 with returns for both as there are not enough cables. Hence screw all the above just fit sensors. Unless you want to go and find the mythical junction box which believe me you would not want to given the possible location and circumstances.
I hope you put brown/red sleeving on all the switchwires/strappersYou've given the game away. This is the existing wiring not the plan. The plan is what to do with it to get to Master and Slave on 1 and 2. I will tell you what I actually did before too long.
How did it go?I've missed most of this,as i had to transport a goat,a fox and a chicken,to an island,using a boat and specific guidelines...
Pfft of course diddly did! notI hope you put brown/red sleeving on all the switchwires/strappers
I thought you were better than thatPfft of course diddly did! not
How did it go?
Been to Tesco then, never mind the horsemeat...Got the order of events wrong,and i now have two nice curries,and red fur slippers...
Reply to Interesting three way conversion to two way and swap for time lag. in the UK Electrical Forum area at ElectriciansForums.net
