O
obiwanabe
Hello
I’ve recently had to rewire my home alarm system as the engineer who installed it did such a shoddy job that all the cables were hardly in and causing the system to trigger every couple of moments. I’ve recently been able to get the system working correctly however, I am unable to set multiple zones as entry an exit points.
I have a magnetic door strip on the front and on the back door and also a PIR covering the front door. I would like to be able to set these 3 as entry and exiting pints but I’m not sure how to as the system just goes straight into alarm mode when either of the sensors is triggered.
Does anyone know how to configure 3 zones as entry and exit points with a 30 second exit and entry time?
Cheers
TL;DR
Set 3 zones (inc a PIR sensor) on ADE optima compact G3 as entry and exit points
there is only one E/E on the alarm ,but you can use any of the zones for it .
in the compact 3 instructions will show you how to change the zones .
ADE optima Compact G3 set entry/exit time on multiple zones
obiwanabe,
buzzlightyear,
