Discuss Optima Compact Alarm Fault in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Hi have an Optima Compact alarm panel, when I set it just keeps beeping, if I set It and open and close the front door it sets, but if I open the front door as if coming home, the alarm goes off straight away. No 1 zone is the timed zone, so I have it in the right connection. Very grateful for some help.
Your door contact is goosed.It sounds like its stuck in the closed position making the panel think that the door is shut.When you come back in and open the door the panel doesn't respond and as you enter other zones,it thinks your a burglar,and goes off.
Replace the door contact and it should work again.
Either that or zone 2 is picking you up ad you enter and it isn't programmed to 'entry route'. If any normal alarm zone picks you up between openng the door and turning the alarm off at the keypad it will go off. As above, has the alarm ever worked? How long have you set entry time too? And what exactly is the right connection?
Thanks for your help, I will change the door contact and let you know.
Hi thanks for your reply, zone 2 is not used, PIR zones are not entered before reaching panel.
panel might need re-programming.test door contact with meter. door closed = low ohms .door open = open circuit.
+ and - should definitely not be in your zone connections, and most door contacts unless grade 3 don't have these connevtions. Houston we have a problem
Reply to Optima Compact Alarm Fault in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Daughter has bought a house and it has a home security system, G-Tag setup. Issue is the alarm panel displays are pixelated and you cant see...
Hi all, Requesting your help please! I know this is an old system but has been working amazingly for 7 years! I had an engineer out who done a...
Hi, My alarm system is a Texecom control unit (Premier 64-w) + Keypad + Sounder, and is using the wired zones 1-4 only, with no additional...
Hi, just wondering if anyone could help me. I’ve just installed a texecom Veritas alarm in my garage at home and can’t seem to get rid of the...
Morning All Qualified electrician, usually stay away from alarms but my friends parents have issues. Texacom Vertas panel, not worked for over 3...
