- Oct 30, 2017
- 113
- 56
- 51,203
- United Kingdom
- DIY or Homeowner (Perhaps seeking pro advice, or an electrician)
I have an old CU with BS3036 rewireable fuses. I'm having the board upgraded soon but in the meantime I'd like to add RCD protection. Can anyone tell me where I can find a consumer unit isolation switch with RCD built in - to fit between the meter and the CU?
