- Nov 30, 2021
- 3,335
- 1
- 2,923
- 3,247,381
- United Kingdom
- Business Name
- Mainline services
No not a problem as such but look at all the extra work he had to do that the customer is going to end up paying for.I personally don't think cutting into a noggin for a backbox is such a big problem in the grand scheme, if it gets the accessory to where the customer wants it. A lot of newer builds don't have noggins in their stud walls anyway.
He cut one more hole than was absolutely necessary, but you saw the state of the wall anyway, hardly a big deal when it all needs patching up.
The cable route in the vid possibly raises an eyebrow, but perhaps it will be >50mm from the surface.
He's supposed to be a well experienced electrician, I dread to think of the amount of shoddy below standard and even dangerous jobs he may have left over the years.
