Petej999
- Aug 18, 2021
- 518
- 359
- 138
- United Kingdom
- Retired Electrician
Bloody hell, I may have to watch tv.
Its a busbar davidYou could watch some idiot on YouTube.
Thought it stood for something else "mother expletetive"I always thought MF stood for ManuFactured![]()
So you would actually do it then after all your other posts.He's not allowed to clamp or make a connection to that sheath, I would have only made that connection as a last resort if there had been no earth at all, and it was going to be temporary.
What he should have done is re-instate the 30ma rcds put the cover on and home for tea.
No, I wouldn't have clamped to the sheathSo you would actually do it then after all your other posts.
NOOOooooo YESsssssSo you would actually do it then after all your other posts.
Excellent tube vids btw DavidYou could watch some idiot on YouTube.
'I would have only made that connection' hints this is what you meant so how would you have made this connection.No, I wouldn't have clamped to the sheath
Earth connection ?'I would have only made that connection' hints this is what you meant so how would you have made this connection.
To the cable sheath after berating someone else for doing so.Earth connection ?
I didn't say the cable sheath, I said I wouldn't have clamped to it meaning i wouldn't have connected to it.To the cable sheath after berating someone else for doing so.
So how would you have made this connection you mentioned in #396.I didn't say the cable sheath, I said I wouldn't have clamped to it meaning i wouldn't have connected to it.
Depends on what connection i find ... but probably some 10mm i think i have some on the vanSo how would you have made this connection you mentioned in #396.
He'll on Strictly before long, "celebrity Spark" what next? "strictly Sparkin"?Still luv Delroy thou , best celebrity sparks by a mile
I don't think you are capable of a sensible answer to support your comment hence your inane follow up posts.Depends on what connection i find ... but probably some 10mm i think i have some on the van
