Will do! I was just trying to check it was safe to leave things as they are until I could get someone to look at it
Good lad ;)
And while you're at it, throw that neon screwdriver away and make sure you don't buy another one !!
No, I don't know why it isn't protecting the circuit (which is why an electrician is coming to look at it tomorrow). But I wanted to find out first whether or not it's safe to still be using any appliances in the house (and if the fuse should have tripped/blown/whatever you guys would say) first, to make sure I don't get a shock from anything or find the place burning down today!
Forums are forums, just like advice is advice. I'm pleased that Jeansie is holding tight and letting a spark look into this. Hopefully they will find out what the reason is behind the fuse/MCB/RCD not doing what it's meant to and see what the spur(s) situation is. I would be interested in hearing what they have to say about it though, any chance of reporting back Jeansie?
I expect the neon driver touched the earth bar on the item being tested whilst in the live terminal and a 3036 fuse didn't blow, it isn't unheard of, however a spark going in to look is the way forward.
Apologies if I should't have asked why it happened...I just didn't want to leave it if something was inherently unsafe in the house (other than the combination of me and a screwdriver).
And I appreciate that I probably shoudn't have been trying to work out what was going on myself in the first place. I was just curious as to why we have these switches that apparently aren't doing anything [so I was checking if they were live - again, just trying to get a handle on what it's all doing], so I can ask the spark if he knows what they were for. (I was never planning on doing the other work myself, but before I wasted someone's time getting them out here to look at it all, I thought I'd check it was actually wired in)
I will let you know what he says!
apologies if i should't have asked why it happened...i just didn't want to leave it if something was inherently unsafe in the house (other than the combination of me and a screwdriver).
And i appreciate that i probably shoudn't have been trying to work out what was going on myself in the first place. i was just curious as to why we have these switches that apparently aren't doing anything [so i was checking if they were live - again, just trying to get a handle on what it's all doing], so i can ask the spark if he knows what they were for. (i was never planning on doing the other work myself, but before i wasted someone's time getting them out here to look at it all, i thought i'd check it was actually wired in)
i will let you know what he says!
Curiosity killed the cat, could have been more in this instance.
I don't think anyone can blame you for asking that question, personally the worry was you and the screwdriver :wink_smile:
I think we would all rather you came hear and asked what was going on than carried on using the thing and got a worse result next time. At the very least you have learnt that there isn't much love for those neon screwdrivers :lol:
Absolutely nothing wrong with that in my mind ;)
