Ok then how would you answer this type of exam scenario or what about if it was real world scenario?
During a PIR on small comercial unit it is unpracticable to isolate the main switch, how can you ascertain a value of Ze? You have tried enquiry but no one will answer the phone?
Measure it.
The only limitation is that you can't remove the earth for a true reading, you put this down under limitations.
