Currently reading:
Lever connectors better than screw down?
Discuss Lever connectors better than screw down? in the UK Electrical Forum area at ElectriciansForums.net
Screw terminations can creep when subject to heating and cooling as part of normal operating conditions. Lever connectors work on a constant tension principle and should be reliable in the long term. That they can be considered maintenance free when suitably enclosed would suggest a considerable potential lifespan.
There are lever connectors which have been subjected to rigorous testing in order to gain approval from numerous regulatory bodies around the world, although I stick rigidly to one particular brand There are also unbranded lever connectors, of unknown provenance, sold through online marketplaces, which I would recommend avoiding at all costs.
I was sceptical of the spring loaded stuff when it first came out, but that was many, many, years ago and it seems all of the field evidence is reputable spring-loaded terminals are more reliable for the average user than screw terminals, and many are classed as maintenance-free when suitably used/boxed.
Reply to Lever connectors better than screw down? in the UK Electrical Forum area at ElectriciansForums.net
