I don't know how these electricians are making any profit on £3K full re-wires , there is just no margin in that price
The last 3 bed re-wire I did pretty basic re-wire just lights and sockets ( no data , no outside power , no car charging point) I think I ended up spending around £1600-1700 just on gear alone maybe a bit more
£3k would leave me about 2 days to do all the work , it just wouldn't happen
I took 7 days and was knackered by the end , 6 to do the re-wire and day 7 to all the testing and paperwork etc
Use all the cheapest stuff available, can do materials for a grand.
£2k, pay the other lads £120 a day apiece and keep the rest. Fudge paperwork etc.
This post is evidence of how they make a profit. They throw stuff in, get paid, and disappear before the customer has time to take a proper look around. usually takes me 5-7 days for a rewire depending on size of house.
Does that include testing before and after?
If you want a big job like a rewire done next week then you have to accept you are not going to get the best job because the guy's doing a good job are generally booked up for weeks or months in advance also the £3K price should set the alarm bells going
I think part of the problem is that many aren't willing to pay a sensible price for this kind of work. It's not helped by loads of people bandying around prices from 20 years ago as a reasonable price for the work. Sometimes quoting these jobs is a complete waste of time due to wholly unrealistic price expectations.
Testing ALWAYS completed after.
Most rewires come from testing gone bad. Not one for taking look at old wiring and jumping immediately to rewiring. Find most of the problems come from someone messing with the original installations.
Been in some 40-50 years old places where the wiring has been left alone and usually tests out pretty well.
There are some who buy a place, see old accessories and board, and decide to rewire before decorating.
Doesn't happen too often but it does happen.
I get that but wouldn't you go in, test to see if it actually needed doing and then advise them appropriately? Thought that'd be standard faire but i've never done domestic rewires so i don't know how this stuff works.
Yes I misinterpreted your question, as a rule you’d be called to the job for various problems beforehand, fuses blowing mostly and you’d know pretty much wether it needed a rewire from often a quick look, older cable etc or else someone has bought an older property and the surveyor has flagged up the electrics (they do this as standard to cover they arse) and the owner is adamant they want a rewire so you quote em, no amount of testing is gonna convince em otherwise as they see the “expert” 😂 surveyor as superior to the scruffy sparks 👍🏻
Not always. Sometimes people decide to do a rewire because they plan to live in it for years and figure they'll get it rewired so it's done. One less thing to worry about.
Like I said, doesn't happen too often.
A rewire can come about for quite a few reasons, and one of them is certainly following inspection and testing, and finding very old cable, or very low IR results, or such a mess that it's beyond further modifications.
Sometimes it's more practical, lots of houses have far fewer sockets than are optimal.
Indeed. I have done this several times, suggesting alternatives to a complete rewire. But sometimes it's obvious as soon as you walk in the place that a rewire is the only way forward.
How do we ascertain if it needs a rewire if we haven't tested it prior?
By inspecting the installation, testing rarely tells you enough about an installation to be able to know whether or not it needs to be rewired.
Testing may reveal that a particular circuit or cable needs to be re-wired/replaced.
An installation can test out perfectly and still need to be rewired based on the inspection.
