Currently reading:
2 single phase meters in series
Discuss 2 single phase meters in series in the UK Electrical Forum area at ElectriciansForums.net
I maintain the electrical installation for an old building that is converted into flats. The DNO only owns the transformer and we have a single electricity meter for the whole site. All of the switchgear is ours and the flats have submeters that are also ours (the management company that own the building).
I've got a flat with an electricity meter in an incredibly awkward place (10 foot up at the back of a tight crawl space). Every year, I have to climb up a ladder and get in there to read the meter and I'd like this year to be the last time.
I was thinking of adding a second meter near their CU. The CU was moved to ground level in another room years ago before I got here - using about 15m of unprotected meter tails, which is an interesting choice but I digress.
My question is, would having 2 single phase meters in series affect the metering of either? I could go and replace the original meter with a Henley block, but it's a pain and if there's no issue then I don't see any point.
I can't think of anything wrong with doing this, can anyone else?
It will also avoid any disputes when inevitably a minor discrepancy arises between the two due to normal tolerance on the measurement accuracy. The upstream meter will also register the (tiny) running load of the downstream meter and should in theory read high, but if it is found to read low then the customer might ask to be billed from that.
Should really be fitted with seals, otherwise live terminals can be accessed 'without the use of a tool'.
Can they? The last couple of digital ones I fitted still required a screwdriver to take the plastic cover off and expose the terminals. It was this sort of style: 1 Phase 100A MID Approved Meter - https://www.cef.co.uk/catalogue/products/4326507-1-phase-100a-mid-approved-meter
That said I just looked on CEF and plastic meter seals are 32p so I will splash out on some of those :)
Reply to 2 single phase meters in series in the UK Electrical Forum area at ElectriciansForums.net
