H
hightower
In the pub so it's behind closed doors.
Went to a job last night, communal area of some flats. Light has been permanently on for years, flat 1 wanted the light switched with PIRs and arranged with the other residents to have the work done. So the job was to make the light switch with two PIRs - one installed out the front door, one installed in the communal area - so that coming home on a night, or leaving on a dark morning the light would trigger.
There was a three-core already installed that I could utilise (tested fine) but had been bypassed. Basically, some tinkering Tom had (years ago) removed one side of a two way switch (wires left dangling live - well, a bit of tape to help) and then wired the other side to bypass the switch totally thus leaving the light permanently on.
Anyhoo, I wanted two PIRs in parallel, which means that if one turns on the other is going to have a voltage present on the switch line - something I don't think electronic PIRs would be too keen on, so I opted for the traditional relay style PIRs to make sure.
I took the light down to fish for the wires to adjust the setup - I needed a neutral at each PIR, so was changing it so that each three core had a line and neutral and a switch return.
Cue flat 2 returning home, "what you doing?"
Me: I'm installing a couple PIRs to allow the light to be switched
Him: Why?
Me: Because that's what I've been asked to do. Something about turning the light off when it's not needed
Him: Do you know how much they cost to run? Pennies!
Me: Look, I'm only doing what I've been asked to do. If you've a problem, you need to take it up with your residents association.
He went in to his flat but came out a few minutes later
Him: Why are you messing with the light then if you just need to install a PIR in place of that switch?
Me: I'm installing two PIRs, I need to get a neutral to the PIR so I'm altering it up here
Him: You don't need a neutral for a PIR
Me: The way I'm wiring this, I do
This followed with a little bit of Punch and Judy style "You don't", "I do" and then I said "look, I'm discussing this no more"
He disappeared in to his flat and came out again two minutes later with a print out of an electronic PIR that said no neutral needed and said "here you are, it says right there" before disappearing back in to his flat before I had a chance to respond.
I didn't see him again after that. When I finished I explained to flat 1 what had happened and explained why I needed to get a neutral to the PIR to achieve what he wanted, just in case flat 2 started making his mouth go.
He was understanding and basically said he was a bit of a know-it-all, I responded "a little bit of knowledge...". Flat 1 said he wouldn't be surprised if it was flat 2 that did the unsafe bypass all those years ago.
Anyhoo, wall of text, just had to get it off my chest as he really annoyed me. What stories have you got of people being a complete pain in the a***?
Him: Why?
