Discuss Baseboard heater wiring in the UK Electrical Forum area at ElectriciansForums.net
castle554
I have two baseboard heaters (1000w and 1500w), both 240V. They are in different rooms of the house. I want to run them on the same 240V circuit- 15A. Two questions: can I put both on the same circuit? And can I simply connect them in a junction box near the panel?
I would have to say that you need to run a separate circuit and with 1000 and 1500 watts which will pull 11 amps at 240 vac and you stated it was on a 15 amp breaker then no since you have other loads on the circuit.
Reply to Baseboard heater wiring in the UK Electrical Forum area at ElectriciansForums.net
I need to add shop lights to my basement. I currently have one baseboard heater that runs straight to the breaker. Its a cadet 240v/4.2amp 1000w...
I removed my baseboard electrical heaters (1981 installed) due to finishing off the room. When I had a new AC ductwork installed they changed the...
Hi, A baseboard heater in my house emits a short buzzing sound every 30 seconds. It seems to happen only when the room is near the temperature...
I’m running wires to the basement for future basement finishing. I’d like to add two circuits of outlets (one on the finished side and one on the...
Hello, I added a 240v insta hot water heater at the kitchen sink. When the water heater is in use the lights in the adjacent dining room flicker...
