Discuss Bathroom electrical works in the The Welcome Forum area at ElectriciansForums.net
I put some news lights in a bathroom and new extractor fan. Did the tests and filled out form. A couple of days later another electrician came in and changed the fuse board and rewired the lighting circuit the bathroom was on connecting new feeds to a joint box I put in. All my readings are now invalid, do I still need to sign the work off as I feel what the other electrician has done supersedes everything I did?
Bit of a sickener they didn't employ you to do the box change aint it? I might, as a disclaimer, point out with that certificate that as the circuit is changed by other work/electrician I could no longer be reponsible for that circuit in the event anything goes wrong with it.
Reply to Bathroom electrical works in the The Welcome Forum area at ElectriciansForums.net
Hi, I'm looking to install a new bathroom extractor fan in my bathroom as I have a windowless bathroom and the current one I have installed in...
I've installed a replacement bathroom extractor fan. Pic on the left is the old one. Pic on right is the new one. Wired the same way but the fan...
Hi, my niece lives in a flat and has a bathroom without a window. There is an extractor fan which packed up and an electrician installed a new one...
HI There, I would be grateful if you could help me, I have a very long duct between the bathroom and extractor outlet vent and for sometime, the...
